has anyone converted a matryx pro with the 2.75 factory anti stab to a khaos using the axys raptor khaos conversion? or do you need to use all factory parts with a longer fts?
I used fox coilover Khaos length shock and oem limiter strap.has anyone converted a matryx pro with the 2.75 factory anti stab to a khaos using the axys raptor khaos conversion? or do you need to use all factory parts with a longer fts?
Did you just drill a hole in the oem limiter strap to lengthen it or did you use an oem khaos limiter strap?I used fox coilover Khaos length shock and oem limiter strap.
There’s zero reason to use khaos rails.
Fits like factory, no vibration or rubbing.
View attachment 382902View attachment 382903
Oem Khaos limiter.Did you just drill a hole in the oem limiter strap to lengthen it or did you use an oem khaos limiter strap?
Raptor, it might only work with their shocks though which I have.RMK - who makes the shock eye extension?
Highly recommend not doing anything to add ski pressure……..I had a quick chat with iceage, they made as mention to risk of stabbing your track if you only use the longer strap and shock with stock pro rails. I believe with the 22 design and factory antistab wheels that issue is no longer a concern.
I'm planning on running the khaos length fox setup with a longer strap on my stock pro rails when I get it ! coming off a 21 khaos, I really like the handling characteristics. The khaos rails may not be worth the cost and hassle at this point. Of course I would have just ordered the 165 khaos if it was an option
I also kept my ice age elevate spindles from the 21, so i'll try those on the boost pony
I just need to get my new sled first ! Come oooon mr truck driver !!!
I see your running just one Khaos strap just fine, Is it necessary for factory khaos to have two straps vs one on the Pro?Oem Khaos limiter.
I just replaced the one strap that the pro had with another one.I see your running just one Khaos strap just fine, Is it necessary for factory khaos to have two straps vs one on the Pro?
