What goggles dont pinch nose?
srt20
130
46
I need some goggles that allow me to breath through my nose.
509 X5 are really tight around my nose.
Aviators are just somewhat bad.
I have a pair of Dragon something or other that are unwearable.
I have a larger head, but my nose is not huge or anything.
Any suggestions to try?
Mentzel
359
212
Scott Snowcross LCG. They have a cut out for your nose. I love them!
I have same problem with nose pinch. Makes me light headed when I can’t breathe through my frickin nose! The LCGs fixed my issue.
I was a die hard Oakley guy. I have 23 different pairs. Finally tried the LCGs specifically because of the nose relief area. The quick change lense system works well. Wish lenses were easier to get though.
Mentzel
359
212
Make sure you get the snowcross version. The ski version does not have the roost deflector on outside of goggles across your nose. This helps keep your nose tip warm at high speed.
Both ski and snowcross versions have face foam recess area around nose.
Wintertime
380
177
Casper, WY
I use Breathe rite strips while riding helps with that. I also find it helps me breathe better. I run Klim goggles and have a pair of Abom's that are awesome they don't pinch. Had the same trouble with the 509's I cut some of the foam away and that didn't seem to help.
Q
Mar 11, 2011
146
91
Olds
I hear ya, My 509 goggles are horrible for it, At this point I'm completely done with anything from 509. Everything I've bought from them ends up in the garbage. Just bought the Klim viper pro goggles and gonna try them out this weekend but they feel pretty good so far.
Mentzel
359
212
Q
Mar 11, 2011
146
91
Olds
  • FOV+ FRAME GEOMETRY FOR MAXIMUM FIELD OF VIEW
  • TRI-TESTED POLYCARB UV400 DUAL LENS
  • FOGTECH HD ANTI-FOG LENS COATING
  • TRIPLE LAYER BREATHABLE FACE FOAM
  • INCLUDES PREMIUM CLEANING CLOTH/STORAGE BAG
  • STRAP OUTRIGGERS*
  • SNOWMOBILE-SPEC OVERSIZED FACE FOAM*
  • AIR FORCE INDUCTION (A.F.I.)*
  • 46MM WIDE GOGGLE STRAP*
    * FEATURES EXCLUSIVE TO VIPER PRO.
*On VIPER PRO Models Only
810
Elko, NV.
This nose pinch thing is a little strange to me. I've been wearing helmets and goggles for 51 years and have never noticed nose pinch. Just got me thinking, could it be your helmet pushing your goggles down on your nose???
Mentzel
359
212
Also note the Scott Goggles are made in Ogden Utah. That’s not important to many these days. But it is important to me!
Definitely NOT China junk!
ziggity
My cheap scott hustle snocross goggles work great no pinching, the LCG look top notch! After seeing my buddy fight with 509s ill never buy their goggles.
srt20
130
46
Yeah I think that has something to do with it. But if I have the goggles up higher so it doesn't push on my nose so much, my bottom eyelashes catch the foam when I blink. I think the goggles are just to tall and the nose cutout isn't deep enough and wide enough.
Those LCG look nice, but kind of hard to come by. You guys have certain vendors that carry them? Ideally Id like to try a pair on with my helmet, but I don't think thats going to happen around here.
Mentzel
359
212
Amazon.. if nobody local
SODAK-DOO
190
53
eastern south dakota
kingpins. bought a pair because my x5's pinch my nose. x5's are going and replacing all 6 pairs with kingpins. only thing with kingpins is the tip of my nose touches the nose piece, but that is miner.
Over budget
231
240
Centerville utah
I have a huge snout. I Pretty much have tried every brand and always end up going back too scott. They are by far the most comfortable for me.
srt20
130
46
So I ended up buy a pair of Scott LCG and a pair of Scott Prospect. They both fit good around my nose. The LCG also have most of the venting on the top so Space between googles top and helmet is crucial or bad fogging occurs. One of my helmets has a flat end there and didn't let enough air in. My 509 helmet is more angled and lets a good amount of air in. The prospect has more vents in the lens and lessens the fogging.
I like the extra lens that comes with the LCG, lets you switch out for more or less sun. I paid $118 on Amazon.
I actually like the Prospect googles a little better. That maybe because the lens color was better in some seriously bad flat light we had. IIRC they are Rose colored. Did not come with a second lens. I paid $63 on Amazon.
The fitment is much much better for my face vs X5 or Aviators.
Thanks for the advice! I will likely pick up a pair of Vipers this off season as well when I find a sale.
Mentzel
359
212
I use Klim Arctic balaclava with the LCGs.. which will deflect breath 100%. Use Klim Glacier balaclava on warm spring days. Only other way they will fog is if you are too hot and your face is sweating. Drop a layer or open coat vents. If you are sweating all goggles will fog. Find the balance of layers that works for you. Leave truck a little cold. You will warm up as you ride. Pack extra fleece for upset situations.
