M
I read on Sawyers clutching thread (and didn't want to hijack) that there may be an update for the Shockwave that requires machining...any info on this? (the more details, the better).
whats the machining on one of these run a guy?
or by any chance do you have any pictures and description for those of us with access to machining facilities and people who are good with em?
clutch mod is $60. plus shipping. give Val a call. 435-760-3789. I guess I will only have a leg up for a little while- that is if I ever get this mcx running julio
sense the secret is out machine .180 off the inside to allow it to let the shieves open more and then you will need to grind alittle off were the top of the ramps contact the shieve, if you take the spring out and slide it back and forth you will see what needs done. I can not see anybody charging $60 for a two minute machine job, thats just not right. if you are in elko I will do it for a few beers.
So, is that 18 thousandths of an inch, or 180 thousands of an inch.. Just want to be sure... Thanks in advance!! Sean
well it must be less to get stuff done in elko. machine shops here in idaho are 75 dolla min. regardless of how simple and fast it is. that is what it cost me to have a little plastic cut off a driver and I had to tell him exactly what I needed because he didnt know.
So there is a less expensive option send your clutch and two beers to snowy1, better hurry as he will probably change his mind after stopping his income produceing jobs to mill clutches and answer calls.
