2022 Matrix - Minor annoyances/Tips and tricks
T
TheBreeze
1,970
518
Sussex, Wisconsin
To start, I am stoked to have a factory boost wagon, and know I am one of the lucky ones to have one on hand already. I love the sled! Here are the minor issues I have found thus far (have not gotten the sled in deep snow yet)
1. Not much room for belt changes compared to the Axys. Found the trick is to always start from the bottom of the secondary, weather installing or removing
2. Grips are spinning on the bars - Been a while since I had a new sled with the spinning grips! Need to try and remove, and add some grip glue.
3. Recoil handle buzzes on the plastic something fierce. Sounds like when I get radio static over the CB. Not sure how to address this one yet, but likely a simple fix
4. Secondary tool is not retained well. I replaced with a hitch pin, and put the secondary tool in my tool kit like a saw from another guy on youtube.
5. Plastic panel with the switches/tether mount sure is loose. I added some plastic push rivets like I saw from another guy on youtube.
Anyone else notice these same issues? Any of your own you would like to add, and how you fixed them?
Again.... I have not been lucky enough to have mine out in the deep snow, so I have not had a chance to really test of the other small issues others are seeing i.e. snow ingestion on the clutches/in the glove box.
Sheetmetalfab
7,911
6,673
Pictures of the plastic push pins you added?
And the hitch pin?
T
Oct 16, 2017
210
298
Of your issues - the panel where the key and tether mount is also lifting up on mine. Haven’t had issues from it though. The secondary tool panel mount is also terrible.
Other thing I’d note is the air filter screens are not glued super well and get blocked immediately in deep snow - and the throttle block is awful with icing.
Sled rides incredible though and minor quibbles aside is a great step up from an axys
Over budget
231
240
Centerville utah
I have to agree. Mine makes all kinds of little wired vibrating noises. The tunnel rattle sounds the worst. There’s a few things that seem a little on the cheesy side
Gideup
54
53
18
Mnt Rainier, WA
My boost right out first ride vibrated and hummed a lot. At 85 miles now, vibration and hum less as belts and track are starting to brake in.
Sheetmetalfab
7,911
6,673
Regarding the tunnel rattle…….
Likely you have loose screws from the dealer assembly.
Run through them with a torx and check.
My 165 boost has zero rattling in the tunnel.
RBalazs
Snowest Terminator
700
741
93
Ya, saw someone bought a 3’x5’ sheet of frogskin from somewhere. Where?
RBalazs
Snowest Terminator
700
741
93
Sorry, spoke before I looked
damx
1,836
1,177
Sheetmealfab they need more air intake area, stockers were getting plugged up alot in 3-4' today.
turboless terry
5,567
6,767
Big Timber, MT
Problem is the shelf at the bottom of them for snow to sit on. Look at 17 or 18 doo. They never plugged. They were susceptible to damage but didn't matter how deep snow was. They always ran.
JH@CM
493
770
93
Vents plugging is a nice problem to have... but agree that it totally sucks.
My turbo doo was great about keeping the vents clear with the turbo blow off through the top vents. Wondering if the boost sleds have a similar feature or if they vent elsewhere?
R
Nov 24, 2014
74
31
18
I have had an issue with my pipe rubbing against the bumper. There is a thread on this but its worth mentioning for those who don’t want to get caught off guard.
I put a couple washers on the pipe rubber and it fixed that.
T
TheBreeze
1,970
518
Sussex, Wisconsin
And the hitch pin?
