2019 600 alpha no revers
dunatyk
932
331
Has anyone else had an Alpha that won’t go into reverse? Sometimes I get a shift alarm when pushing the reverse button but the sled will not go into reverse. I’ve swapped the handle bar control unit and tried a different hood and still nothing. Hoping someone else has seen this problem and has a solution
Ol* Geezer
173
86
If it is idling too fast or the temperature is too high they won't go into reverse.
IDspud
3,973
Oakley, ID
Interesting
We’ve got a 14 6000 that loves to die mystery deaths in island park, then runs fine an hour later. Never done it anywhere else.
kiliki
13,213
2,398
Nampa, Idaho
It has been flashed once for a mid range bog. Done by the guys in Island Park.
did it start the no reveres problem after this? I know cat did a map programming tree change between 2019 and 2020 as all the guys doing ecu "tunes" had this problem.
gp800
208
205
No the issue was present prior to the reflash.
