Light weight battery
Cinno
168
Stillwater,Mn
I used a Shorai LFX27A3-BS12 rated at 405 CCA. Fits in stock location on my 2020 MC M-8000. It includes shims to snug up the fit. Only used a few. The + terminal is on the PTO side which matches the stock battery. About 3.5 lbs. So far so good however haven't been in negative temps yet.
line8
1,558
532
West of East
I thought i should give a little info on what I ended up doing to tie this one up. I removed the small car battery first.
I did a little internet researching and settled on
an EarthX 14C. Install wasn’t too bad but there was a small amount of wire moving around and a lot of foam material needed to make it fit right.
I rode it yesterday in low to mid 20’s temps and it cranked right over all day just like the oem.
Dam Dave
4,302
2,252
Montrose
-25 this morning is west Yellowstone, Shorai battery, pushed the button once and turned over slow, waited a couple of minutes for the battery to wake up and it spun up fast and started sled no problem on second try
Cinno
168
Stillwater,Mn
It started up OK at -19F on Feb 4, at Togwotee Lodge Wy.
