Light weight battery
line8
1,091
200
Oly
Not much info on this. What light weight batteries are people having good luck with?
97
Stillwater,Mn
I used a Shorai LFX27A3-BS12 rated at 405 CCA. Fits in stock location on my 2020 MC M-8000. It includes shims to snug up the fit. Only used a few. The + terminal is on the PTO side which matches the stock battery. About 3.5 lbs. So far so good however haven't been in negative temps yet.
line8
1,091
200
Oly
I thought i should give a little info on what I ended up doing to tie this one up. I removed the small car battery first.
I did a little internet researching and settled on
an EarthX 14C. Install wasn’t too bad but there was a small amount of wire moving around and a lot of foam material needed to make it fit right.
I rode it yesterday in low to mid 20’s temps and it cranked right over all day just like the oem.
Dam Dave
4,169
2,040
Montrose
-25 this morning is west Yellowstone, Shorai battery, pushed the button once and turned over slow, waited a couple of minutes for the battery to wake up and it spun up fast and started sled no problem on second try
97
Stillwater,Mn
It started up OK at -19F on Feb 4, at Togwotee Lodge Wy.
