Any videos out yet ?
TTTAny videos out yet ?
Side by side comparisons hardly prove anything. I think they are a giant waste of time.
I believe part of it is the weight balance of the sled. More weight forward and heavier overall on the matryx. Rear spring is still a 180. Although valving could be different. My 21 seems to be more plush than my 23I just rode a 21 850 kaos and 9r kaos 155 back to back. Bottom end on 850 was lame. 22 is better. 21 kaos was a lot more rowdy than 9r. Must be sprung different.
People don't realize how much difference there is even though suspension is the same. Didn’t know if there was a spring difference. 22 matryx kaos boost 155 wasn't out of hand at all. Would've been packaged in a 21 axysI believe part of it is the weight balance of the sled. More weight forward and heavier overall on the matryx. Rear spring is still a 180. Although valving could be different. My 21 seems to be more plush than my 23
Sent from my SM-G991U using Tapatalk
Ya my 21 155 is waaaaay more playful. Kinda makes me disappointed in my khaos 165. Its probably going to become a shorter sled. The spring rates are the same according to parts diagram.People don't realize how much difference there is even though suspension is the same. Didn’t know if there was a spring difference. 22 matryx kaos boost 155 wasn't out of hand at all. Would've been packaged in a 21 axys
The matryx is more nose heavy.Ya my 21 155 is waaaaay more playful. Kinda makes me disappointed in my khaos 165. Its probably going to become a shorter sled. The spring rates are the same according to parts diagram.
Yep weight balance is definitely more forwardThe matryx is more nose heavy.
Really makes all the difference.
I don't understand why.Yep weight balance is definitely more forward
Cooler forward and bodywork weight makes the COG further forward.I don't understand why.
Others have talked how layout and 'hood'' are basically the same between ayxs and Matryx.
Could be with 5 or so less lbs on the tail of the tunnel due to the shorter tunnel coolers?
Are these matryx sleds that feel so nose-heavy - do they have electric start?
Sent from my SM-S906U using Tapatalk
Ditch the poo track.Ive got 390 miles on my Matryx khaos. Yesterday I finally came to that conclusion. Have a 21 also.
How to change that? I tightened up the front track clickers, that wasn’t the ticket. It needs some ski pressure otherwise it becomes a little bit of a work out.
Lol headlight delete he says. Let's just say out west we don't have lakes to race across. Our uphills are speckled with trees. If you're out west than **** a different track unless you're on team Polaris or Klim. The only **** worth it is actually riding it and determining the correct suspension setup.Ditch the poo track.
155 lynx, doo, camso 300LX.
Any will cure it.
Headlight delete
(goodquiet) can.
How drunk were you when you wrote this? lol. I can't understand a thing you said here.Lol headlight delete he says. Let's just say out west we don't have lakes to race across. Our uphills are speckled with trees. If you're out west than **** a different track unless you're on team Polaris or Klim. The only **** worth it is actually riding it and determining the correct suspension setup.
