2016 M8 Limited not running right
dw8
66
32
18
My father has a 16 limited that has developed a pretty substantial bog. Started to show up about a month ago around the 1500 mile mark. It's not the usual bog/deadness you get when at idle and punch it. It really shows after the machine has been ridden for say 10 miles and is warmed up. Happens when going from around 1/4 or 1/3 throttle to pinned. It spits a cloud of smoke and just has no power. It doesn't snap like my 13 does in that situation. It has fouled 2 sets of plugs. About 120-150 miles per set. We ride in Maine between 1500 and 3000 feet. The only mod is a ggb can that was added around the 600 mile mark. I don't have a lot of experience but I'm pretty mechanically savy if I can get pointed in the right direction.
Any ideas? Thanks in advance
Oh and there are no codes being thrown
007
935
182
Spooner, WI 54801
www.4seasons.com
Three things I would do.
Replace all 4 plugs
Pull exhaust valves and make sure they are in spec
Clean clutches and replace the clutch springs
That is the first things I would do in that order
Cans can cause a bog also. If there don't work go back to the stock can and retest.
kiliki
13,213
2,398
Nampa, Idaho
I'm no expert but, maybe a chipped reed?
with the miles ^^^ this. stock reeds do show signs around 1500-2500 of needing to be replaced and what you have described i would bet this is the problem.
also behind the pin the flipper pivots on is the throttle safety switch you can undo the screws holding the cover in place and un plug it.
sno*jet
2,827
1,298
ive read reports on here of sticking oil pumps. i checked mine and all is good but check yours for sure. (second set of eyes on the arm while you work the throttle)
