Yes cat paint code medium greendid you paint the rail?
I did not, hope it holds upThat's what I did. Did you clear coat it at all?
i picked up the rail,drivers,aluminum shaft,shocks and track from kanedoggy! I also had to source out the newer style brake caliper as it’s thinner and rotor with a couple spacers. My 18 was earlybuild so it had the steel shaft[/QUOTE]What was the cost of the ALPHA swap. I want to do the exact same things rail & elevate. Did you have to buy alpha rear shocks or did the 18’s work
Paint from catlooks good!. Did you just spray bomb the rail or was it powder coated green?
That paint should hold up fine, its an enamel paint and is strong as long as it cures 100%, which takes about 30 days. If you have a warm sunny day park it out on the lawn and it will help speed things upPaint from cat
