https://youtu.be/AsrsKH7vpao
Got a little more footage on this video. Did I say how fun this sled is...
Well I traded in my 2019 850 Axys for an Alpha. Very happy with my decision. The Alpha is just plain fun to ride. Handles great and has no lack of power.
I have a problem with washout ven it is steap...cant hold the same lines as my buddies whit the axys rmk 850s. Does any one know a good setup for the rear suspension?
Was ur last sled a Polaris?I have a problem with washout ven it is steap...cant hold the same lines as my buddies whit the axys rmk 850s. Does any one know a good setup for the rear suspension?
Did he have the rear shock locked?Buddy on his alpha was doing the same thing. And he sure trenched a lot. I loved razzing him after he was stuck!!! He rode his Axys much better, but could have just been the day!! It was 2' and epic, but only his second ride on the alpha.
SnowTrax be like
Mountain sled of the year goes to... Polaris 850, despite bearings melting to the crank, and oil lines falling off, the 850 really opens up with a wild 15hp more than the 800 which can be manipulated with just a flick...
I find that I use a lot less throttle on the alpha than my axys. The alpha track hooks up extremely well. On steep side hills you stand on the rail and use the throttle to point the front up or down. Where you position your feet on the board is critical to what the sled does when you give it throttle. It’s super easy to ride once you figure out how to not override it.
Sounds like ur thumb is the biggest problem And rider position second issue.
With a Polaris u can squeeze the throttle to the bars on a steep sidehill and the track just spins like crazy and u move slowly.
With a cat, u do that and u are either going to go very fast or turn up hill real quick.
The Alpha will turn up or wash out even quicker, if ur to far off the side of the sled or standing to far back and hammer down real quick.
Yes my last sled was a axys rmk 155. Maybe the alpha is not as good as axys in the really steap sidehills. I vil try to stand more forward on the runningbords and maybe get more psi in the rear suspension.
