M
What can u do to make the front end feel lighter on an xp? Hard to boondock just feels heavier than hell. Came off polaris and there seems to be a big diff. Wears a person out by the end of the day.
X2....just a few inches back and it's a different sled. once you get it in the right spot, the front end will feel light as a feather. wheelie when you want, step forward and it stays planted for climbing.rotate your bars back. loosen up the riser at the bottom and roll it back. puts your weight back a little making it easier to steer.
jUST SELL THAT P.O.S and buy a real sled, like one of those excapes i hear they go good in the pow. lots of floatation. p.s. ill give ya 10,000 for that front end heavy 860 xp that will climb higher than any non turbo sled out there. sory they dont handle as good as one of those tub trailing arm chasis for all that road riding we do.
When you guys say limiter out one hole you realize that you are also giving up climbing ability for easier handling aren't you? Because lengthening the limiter will bring the front end up in turn having less track on the ground.
I make u a deal 12500. and that 500 mile big bore will be in your garage. And ill start my dragon mod. No joke. Thats what i have in not counting any labor.
Limiter out, remove the sway bar.....by far the easiest and most forgiving chassis to ride when setup properly.
Keep your sway bar in for the trail ride up there, and then just remove it when you get in the mountains. It's night & day difference with it in on the trail. It only takes 5 seconds with the quick release. JMO!
