Per request I am starting a new thread. This will be ongoing and I will add info as I go.
So far I used a 2009 530 ktm frame thinking it would fit tight. Not the case so I'm we have cut the bottom out to fit the engine properly. Eric82930 cut the side panels for me and mirrored the geometry of a machine he has been tinkering with for years. We shoved the skid as far under the engine as we could and modified the frame to receive. The only way this would happen is through the people I know. I would not have been able to pull this off... its a lot of modification (more than I was expecting).
The panthera engine transaction was easy and delivered on time. So far I have had to order separately the throttle and clutch assembly, along with the spark plug wire assembly.
I am putting an aluminum 7 gallon fuel tank on the back under the seat with a tunnel cooler from an artic cat. The skid started as a 120 aro that I got a good deal on then converted it to an aro 3 since the side panels were being recut.
I have attached the dyno for the engine before it left with the snowbike pipe. Thats for this specific engine.
Sent from my SM-F916U1 using Tapatalk
