I recently purchased a used Timbersled rear suspension for an apex and used the stock yamaha slide rails, then decided to cut the rails and put them flat like the iceage rails. Everything was lined up straight with a jig and then welded. I was wondering if anyone could measure the distance from the center hole on the front suspension mount arm where the suspension bolts to the slide rail to the center hole on the rear suspension arm where the suspension mounts to the suplied bolt on bracket for the rear of the slide rail.
Thanks
Thanks
