G
1st clean clutches often on first ride (scotch brite pad).
2nd gear from 21 to 19.
In the primary put in 433 ramps or ramps that the rt 1000 used.
Make sure your primary spring is 160/290 or 160/320 or close to.
Load your pin weight to 16 grams for 154" track or 15 grams for 163" track.
With hollow pin it is 12.5 grams.
Leave the secondary stock!
Gearing down and throwing more weight will allow the clutches to pinch the belt and eliminate slipping preventing heat. It will also will increase track speed allowing you to kick a** without blowing belts.
This set up is for 5000ft and higher. Don't be afraid to ride in clicker 1 or 2.
My 2 cents and have fun.
