Clutch spring
M
minus40
213
96
What would cause primary springs to deform in as little as 50 miles on a new clutch. New Polaris springs go in straight and come out with quite a lean on them. I could tell when one was out of shape as the rpm climbed a little as the spring was binding on the spider lock nut. Lots of alum filings as well from both spring pockets.
sled_guy
3,566
843
Riverton, Utah
Check that clutch closely in a couple of areas...
1 - The shims under the spider. Make sure you don't have one hung up keeping the spider from screwing all the way down in to place.
2 - Make sure your towers and cover a lining up and bottoming out against each other.
3 - Make sure the clutch is screwed tight together, that the spider/moveable sheave can't/isn't spinning on the shaft.
Otherwise I don't know how they could tweak like that, they are pretty tight in the spring pockets typically.
sled_guy
M
minus40
213
96
Thanks, that all checked out. Next step was to put a dial indicator on and check spring pads for square. Then balance. However a new one is on the way so might not waste anymore time on this one.
kanedog
Undefeated mountain clutching champ of the world.
3,112
3,873
Give Lonn at Thunder products a call. Let him know your problems and he will have what you need.
retiredpop
1,350
295
83
Calgary
It's because you're a Rider fan and it has to lean like your avatar:face-icon-small-ton
CO 2.0
2,994
Fort Collins, CO
What spring are you using? On my 12 pro I noticed poo, slp, and speedwerx h5 springs had thicker or thinner coils depending on brand, and would rub/stick on both ends. Ive run thunder products metal glide washers in my clutches for years now on Polaris and Cat primaries. Helps spring bind a bunch. I usually run one on each end of the spring. Each one will raise clutch engagement by 50 or more rpm fyi
M
minus40
213
96
Polaris blue/white, black/white.
So your just running one plain steel on each end? I was thinking of one steel against the spring and the coated one under that against the clutch. Maybe that's overthinking it?
That will take up .080 in space. Is there enough room that you don't have to worry about coil bind? i suppose that will depend on spring and how tight the pocket actually is.
