Clutch rubbing on side panel
SnoPro1000
283
115
I have read somewhere that the primary clutch was running on the side panel. Can anyone confirm this or if anyone has seen this on the 2018 I know there's a brace at the belly pan to help stop that.
Thanks
SnoPro1000
283
115
Very good to know thanks guys,
When I heard this I thought it sounded fishy lol
D
Dabull
399
utah
It rubs first thing I noticed when I took the panel of the dealers demo.
spag900
101
19
18
Dealer's demo one close to me has same signs of rubbing against the foam insert that is attached to inside of panel. This is the primary clutch I'm referring to here....
CO 2.0
2,994
Fort Collins, CO
18 Primary clearance is about the same as my 16 with sucked in belly plastics. But that brace on the 18s helps a ton. My 16 has a lot of wear on the belly plastics right where I cut down the rivet.
cpa
806
539
93
Utah
Saw one on a dealers floor that he said they had taken out for "one demo ride" and not only had it rubbed the foam but it rubbed a hole right through the side panel. Super excited about this sled but I have to believe even with the bracing it will be a problem.
kidwoo
2,630
1,875
Fake news!!
sno*jet
2,828
1,298
^LOL
well, perhaps the first bug we will see get worked out for the '19 models...
SnoPro1000
283
115
Oh bummer!! Lol that sucks I wonder if that would be warranty? Hmmmm?
cpa
806
539
93
Utah
I really doubt cat would consider covering that under warranty.
SnoPro1000
283
115
Well to me, it's a problem it's a mountain sled made to carve and lay over on its side. The fact that it rubs isn't my problem it's a bad design they're problem correct?
DDECKER
4,770
1,780
CRAIG COLORADO
calm down cat is fixing the issue and all 2018 sleds come with a cosmetic kit to fix all issues
th
now you see why 2 colors are options duct tape grey and black, there the most common duct tape :)
smokindave
Canada Moderator
1,950
Calgary Alberta
I don't think I have ever very owned a sled that I didn't do that to and none of it was from ever sidehilling.
That's what happens when ya ride in the trees.
If you ride trees and never scrap em or getting wedged between trees you certainly ain't riding hard enough in my opinion!
SnoPro1000
283
115
th
I love you enthusiasm but on a brand new sled I'd like to not have to put duct tape lol just yet
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Just like the current panel, i bet it will never rub when sidehilling.
Now if u lay it on its side with the track in the air I'm sure it will rub, just shut it off instead of letting it run.
last
cpa
806
539
93
Utah
I agree they have never rubbed sidehiling and I'm sure the new ones won't. You roll the sled with the motor on and it will rub just like they always have. The answer is for Cat to put a tether on the sled from the factory. Not sure why that isn't standard equipment, makes things so much safer. If Cat offered a few more color options and a tether it would be pretty much as close to perfect of a stock sled as possible IMHO.
