Yes,thankyou for taking the time for those excellent pics..totally awesome
Great photos for last minute snowcheckers and for the rest of us to look forward to that checked one already
Thanks for taking the time to take the pics and post them for us unlucky enough to put our eyes on one. Excellent details that I've been wanting to see. You took them of the right color too! What did you think of fit and finish?
Boy it's going to be a long long summer
What about the 2.6 sizes did u get any? I seen it just didn't measure it
So will the 3 inch pro have the new center drive drivers as well?
This is the only sled in town.
Half-naked Assault ...
Btw, does anyone know the weight of the different tracks?
Polaris say the following about the Assault (http://www.polaris.com/en-us/snowmobiles/800-rmk-assault-155/specs):
Track Width/Length/Height (in.) 15 x 155 x 2.25 Peak or 2.6 Series 6
Estimated Dry Weight (pounds/kg) 427/193 or 418/190
9 pounds difference! Is that only related to the track ?
Good catch. I am going in tomorrow to snowcheck an Assault and was considering the Peak. 9 lbs seems a bit much considering it's also a single ply design.
Be nice to get confirmation on this.....may affect my decision. Took me over a month to finally make a decision and now this......:face-icon-small-dis
EDIT: Just did some research....the current 2.4 track is 47 lbs. The new 2.6 is 3 lbs lighter @ 44 lbs. The 2.5 Peak is 56 lbs so take a couple lbs off for the 2.25 Peak and the difference is as per the specs.....9 lbs.
How much does 9 lbs in rotating track weight affect 'real world' performance?
Just random underhood sledporn.
Sweet new wire wrap material around the handwarmer and thumbwarmer wires.
Also the reverse switch wires.
This should stop alders from thrashing them in cold weather.
The tss and reverse button wires remain in the thicker vinyl that they always have.
Good inner front tunnel bracing.
Basically three layers of metal from the chaincase/bearing retainer to 3" behind the front torque arm bolt.
And then they dimpled all three.
This looks bulletproof.
<a href="http://imgur.com/1bq9byG"><img src="http://i.imgur.com/1bq9byG.png" title="source: imgur.com" /></a>
Rotational inertia refers to the fact that a rotating rigid body maintains its state of uniform rotational motion, which means that it resists any change in the axis of rotation.
Exactly how much that affects the "flickability" of a snowmobile is for some physics professor to calculate. But I can tell you one thing, the physics laws of rotational mass are NOT intuitive.
Watch what happens at 1:15 in this old video clip and then imagine what is going on in your sled ...
https://www.youtube.com/watch?v=NeXIV-wMVUk
Cheers!
Thanks, that was interesting to read.
I'm not sure what question he was answering, but I do know that it takes more power (or longer time) to accelerate and decelerate the rotation of a heavier object than a lighter one. Since a mountain sled does a lot of track spinning it would probably be more appropriate to view the track as a rotating object than not.
I take it you watched the clip, why did the wheel not fall down when it was rotating?
Simply because rotating objects resist any change in the axis of rotation. I was just trying to make the point that the more rotational momentum you have in a sled the worse it will handle.
Now I need to figure out how to shave a lot of weight of my clutch.
