Aftermarket Shocks
xc_rider08
1,520
215
Mandan, ND
Hey all,
Looking to upgrade shocks on the powder pony. (2018 axys 800 163)
Looking to do shocks all around. Last trip I blew out the rear track shock and figured this might be a good time to treat myself to a better ride. Looking at raptor kinetic series or elka stage 4 or possibly something else?? I wld like a coil over shock, I don't do big drops or jump. Just typical mountain riding. What everyones thoughts. Looking for first hand experience to help persuade me in the correct direction.
TIA,
xc_rider08
pics from the last trip to BC for attention
Dec 16, 2011
580
569
93
Eastern Washingtom
I really like the zbros shocks. I think they’re all pretty good seems like a lot of the top riders who are not paid by Fox don’t care much for the air shocks. Carl’s cycle does a good job with revalve too still no comparison to ohlin zbros, raptor etc.
wonderxc600
106
MN
I just picked up full set of Exit shocks and I noticed a big difference from factory. I would do it again without hesitation. I was going to get Raptor shocks, but I got a good deal on the Exit shocks. You can't go wrong withe Raptor, Elka, or Exit.
goridedoo
3,868
3,544
Carls does a good job with valving as well. I’ve had Raptors (not kinetics) and the latest Burandt Floats. I prefered the Carls valving over both.
I have no experience with TRS valving but I’ll probably go that route next year. A little cheaper than Carls.
b-litt
464
531
93
McCall, ID
m.youtube.com
I’d give a good look at the revalve. It’s a big difference in performance and will last much longer than stock before needing rebuilt. I rode a sled with Carl’s valved mono tubes that felt pretty dang good! I’m sure TRS has his valving dialed too.
Keep in mind if you buy something like the raptor kinetics they have clicker adjustments for both compression and rebound. Between these two adjustments and the spring preload there’s a lot to get right or screw up.
I’ve ran fox rc3 coils and air, exits, and both raptor and raptor kinetics. The standard raptors are my first choice if budget isn’t a factor. I’ve also been very impressed with the walker evans velocity shocks. If you can find some take offs of those.
Snowman.PRO.
275
47
MN
I'm currently on Raptor Kinetics. They are definitely a big upgrade over the stock walker clickers that came on my sled. That being said, they are also a TON of cash. This is my second season on them and they have worked great. I don't do huge jumps, but I do some smaller stuff and they take everything I throw at them. They made the sled a lot easier for me to get on edge and side hill.
I have ridden FOX qs3s on XM doo a few years ago. They were good too. Only rode 1 day on them, and this sled only had them on the front.
The next best shock I've ridden is the Walker needle shocks that came stock on a Switchback Assualt 144. The Rear track shock was ok but it did bottom to easily. The Front ski shocks were awesome.
If I had to do it over, I'd strongly consider re valving my stock clicker walkers from Carls cycle. Many people on snowest seem to speak highly of them. However, I haven't ever used them.
OR I'd look for stock Walker Velocity shocks. The Tech involved with these shocks is similar with Raptor Kinetics, being they are a Internal by pass shock. Just like Trophy trucks use.
Sheetmetalfab
7,911
6,672
The velocity shocks off a khaos on my 2016 continue to impress me.
Smooth and the lo speed compression adjustment hold the wheelie factor really well at 5#.
(Fox internals and good oil from carl’s cycle center)
xc_rider08
1,520
215
Mandan, ND
thank u all for the responses.. so many choices. I will be looking into all options. hadn't really thought about the revalving, but definitely an option if money comes into a factor.
goridedoo
3,868
3,544
Money not considered I really believe my revalved monotubes rode better than the high end aftermarket shocks I’ve had.
QUOTE="b-litt, post: 4353023, member: 117305"]
[/QUOTE]
Just wondering what we’re your spring length and settings on your Raptors? Just bought a set and trying to get some options on setup.
Thanks
Just wondering how you set up your Raptor s? Spring length and clickers settings.
Just bought a set and trying to get some options.
Thanks
FatDogX
3,307
1,578
ND
Another vote for Raptors!!! Not only are they an awesome shock but Jake takes care of his customers!
I have run them on the last three sleds and they have been great!!
Chadly
Forum Expert
2,314
4,565
Snohomish, WA
I'm surprised nobody is saying Burandts Fox Floats. Everyone who has ridden my sleds has went and dropped the 2800 for them. Just like posted above all these other ones are too hard to set up. You just put in Burandts pressure and boom you have one of, if not the best set up available. Spring shocks are so 1990s. Last time I rode with Cody Monroe he broke his spring in a ski shock. I have yet to ever see a air shock fail.
Spaarky
3,429
1,345
Chester, SD
Most people do not understand used properly Floats are high maintenance. Where do you check your pressures? Do you do it daily? As temperature and elevation change so does the pressure. Air shocks fail plenty.
Burandts pressures are a starting point, and his pressures are fairly specific to him. I can tell you those pressures were close but do not necessarily work for everyone.
goridedoo
3,868
3,544
Believe me, we ALL know you chit $100 bills, but there are way better things to spend $2800 on than mediocre shocks. They work ok. But are just that, ok. Buddy and I hopped back and forth between his Axys with factory clickers and my sled with Burandt Floats. We both agreed almost no difference in ride quality with the exception of his FTS bottoming out on big whoops. He has never touched it from the factory. Likely just needs to be tightened.
I’m 170lbs and ran all shocks within 5lbs of Burandts recommendations. Meh. I sold them.
Seen many Floats fail. Seals must go out? Mostly on M series. They are also a PITA to get the pressures exactly where you want them beings they dump air when you remove the pump.
