How many guys have done the 280 camso on a earlier proclimb along with the drop and roll MC update? I have do so and have a track rub issue someplace seems only on deceleration when going over a bump or dropping off an incline. any ideas?
Loose track?
I did the MC drop and roll on a 2016 800 ltd with a Kmod rear skid...
Your track is hitting your tunnel. Look under there and you'll see a bunch of black marks...that is where it's hitting. Increase the track tension a bit...do it to spec where you hang weight from it and check for how much is sags.
what year of rails u running? did you cut them down for clearance? at the anti stab?
^ Just do this
Trim your rail caps to the minimum or better yet, remove them. I did this on my 2015 with a 3" Powerclaw and so far, do good.
It's possible the rail caps are hitting the drivers.
There's no rail caps on my ice age rails in my Kmod skid. Just an anti stab kit.
Made try removing rail caps and adding a anti stab kit.
yes it can happen hope this helpsSo the rails hit the drivers?
Just thought I would give a final update in-case this thread is ever found in the future, I cut the rail caps back and rounded them a little, got to ride this weekend and not one time did the problem reoccur. so advise to anyone doing the drop and roll, Trim your rail caps!
