Yes getting snow in it. It's a straight shot to the belt drive unlike the footwell holes and I know a little snow won't hurt, but all I can imagine is it keep building up and icing right below the belt. There was a terrible fit and that hole went all along the bottom of the belt drive. The Polaris guys didn't even notice it and were stumped, eventually claiming it was just a pre production sled with some issues stil.
Thick bead of black silicone?
Why in the hell should you have to do that on 13-14k sled. I'm sure it will not be that way on production models, but if it is I for one would be pissed. I cannot get away with that in my business and would not let them.
Actually, I have a thought that's 180° from my previous answer.
I'm not saying they should all have that gap there...but....
Drainage.
I've had days where I had BIG snow build up around my bottom gear that turned to ice after it had nowhere to go. It came in through the footwell, hoot vents and shock tower plugs.
When it melted it has nowhere to go if you seal that off under the gears.
That's the lowest point under that gear, so the water will collect there (and become ice if it has nowhere to go.
I have a VanAmburg drop pan under my belly pan, so I made sure there were a couple drain holes in the plastic belly pan so the water could escape.
