146 RMK
Wheel House Motorsports
29,933
5,970
SW MT
Well, after a weekend of test riding, jumping and about 1000 wheelies I have to say. The Axys RMK shortened to a 146 is a LOT of fun. This build was only to run for a few late season rides and see how I liked it. Definately putting the parts back on the shelf once the snow is gone and will be converting my 850 khaos to 146 by late march next year.
The build:
2018 Axys Pro 155
Pro QD pullies for geardown
TRS Clutching
Straightline Performance pipe/can
Elka stage 5 shocks all around
To shorten the sled I used:
IceAge performance bomber 146" rails w/ 8in wheels
Composit M66 146 2.6" track.
I had already chopped 5in off my tunnel this winter running a 156 3inch so the tail end was already plenty short. the 146 looks pretty perfect under it. If i were going to stay fulltime 146" I would have cut more off but the 5" cut is a good balance for running both.
This sled is stupid fun. The pipe/gearing/clutching combo comes out of the hole FAST. I can actually bunny hop the sled with a quick gas brake combo move. Its not a TON faster as its still a fairly tall lug track and 2 ply so similar weight as my 3in. BUT how it transfers weight is incredible. It is so cool to rally around on and 'jib' off just about anything. I ride it a lot more like how I would ride a dirtbike and a lot less like a snowmobile. It still climbs fairly well but definately will flip over quick if the snow is soft and allows you to trench in. Hopefully I'll have some photos and videos from this weekends adeventures to share.
For those wanting a 146 but dont want to go to the wide boards/laydown steeering/big seat etc of the Switchback assault model I can assure you building it off the RMK will make you a VERY happy camper.
29,933
5,970
SW MT
The shot with red rails is the 156 ans chopped tunnel. The black rails on the flatbed is the 146 setup as its sitting right now.
Sent from my SM-G960U using Tapatalk
29,933
5,970
SW MT
I do skid and rail swaps all the time so my times are below average. This track is center ported so just direct swap onto stock 2.6 setup. For rail and track swap its probably judt over an hour it takes me.
For next winter Im planning on having 2 driveshafts 1 for 3 pitch and one for 2.86 then also do 2 full skids with my different shocks. Stock khaos 155 for the powder setup and 146 with elkas for spring jumping.
With full skids and driveshafts its probably a 30 minute project or less to from one setup to the other. The belt drive axys chassis is really easy to work on, especially with the belt drive installation tool.
Lobster Carl
134
160
If you were to go 146 all the time how much would you cut off the tunnel vs the 155?
Sheetmetalfab
7,926
6,687
You need to find an excuse to own 2 sleds. ?
They rack up less miles that way. ?
29,933
5,970
SW MT
If I was going to cut one, 10" would make it so the back is totaly vertical. This would be ideal if it was a fulltime backcountry sled. If it was a sled that saw a bit of trail miles and variable conditions I'd cut 8" and leave a full length snowflap and you shouldn't have any cooling issues.
On the note of 2 sleds, I've had them before and what I've found is that it makes it that much harder to keep things in tip top operating condition. Im VERY obsessive about maintenance and little details and have 2 sleds gets rather overwhelming to keep tabs on it all. Its much easier to have 1 setup that is just 100% dialed and just swap some parts for conditions.
Also when I have 2 rigs I find myself loaning the second one out a lot and if anything I rack up more miles then before. Between depreciating 2 rigs a year and the extra milage it made way more sense to have 1.
29,933
5,970
SW MT
Im actually still running the pro rmk pulleys (which are a slight gear down vs stock)
I tested both stock 155 Axys RMK gearing and the Pro pulleys. The stock gearing felt a little faster WOT across the flats but just a lot more lazy and boring feeling for lower speed riding. Mind you all my test riding has been done at 8000'+ and 40*F + weather so im sure cold days down lower it could pull a LOT more for clutching and gearing. But for it to be this lively in these low air density situations makes me a happy camper.
The 146 with the Pro pulleys and TRS clutching is rediculous snappy out of the hole. Like I said above, you can bunny hop it.
BeartoothBaron
1,249
1,326
Roberts, MT
I'm still riding a 144, and while I'll go longer with my next sled, I agree there are a lot of benefits. In the deepest stuff I saw this season – mid-February up by Big Sky, and granted, I didn't get in as much as I'd have liked – I had no trouble getting around. Makes me wonder why they don't at least offer a 146 Pro-RMK as a custom order.
I'm totally with you on this. The more I learn, the more I keep tweaking my sled. A lot of the fun is getting to the point where the sled has quick throttle response across the range, holds perfect RPM, and so on. I wouldn't say I spend as much time tinkering and upgrading as I do riding, but it's probably close to a 1-2 ratio. With two sleds, it's pretty easy to see that approaching or exceeding 1-1, assuming riding is evenly split between the two. A pure backup is easier: as long as it's reliable and you can pull and go, you're probably not going to sweat the small stuff. I don't even have a backup yet though, probably won't until I get a newer sled.
29,933
5,970
SW MT
It flies really good... FYI
<blockquote class="instagram-media" data-instgrm-permalink="https://www.instagram.com/p/ByVdG-ZA3Oo/" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/ByVdG-ZA3Oo/" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/ByVdG-ZA3Oo/" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by Nick Donovan (@skidooin_it)</a> on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2019-06-05T16:44:29+00:00">Jun 5, 2019 at 9:44am PDT</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
dboe03
120
38
Fargo, ND
I'll just be here waiting for my wish of a factory released Pro RMK 146. Be the perfect Midwest/UP boondocker and still be just fine for what I do in the high altitude stuff a couple times a year.
29,933
5,970
SW MT
How bad do you want it... This sled is about to go up for sale..... Never jumped, only trail rode ;)
Also building one is super easy aside from the tunnel cut, and I know some people who are working on a kit to make cutting/shortening the tunnel WAY easier. Much less guess and more just cut/weld a new piece on. If its something your after, by the time you sell stock track/rails the upgrade is a few hundred bucks and only takes an hour + tunnel cut
F
Sep 25, 2016
10
Question. Did you just buy the iceage 146 rails and everything from the 155 skid just bolted up in the exact same position as they did with the 155 rails? (No moving rear suspension mount?) I'm looking to do the same to my 19 sks 155 and looking for answers.
