174"-146"
B
burnz
Jan 7, 2013
106
33
Nanton, Alberta
Looking for any advice/ tips for going from 174 down to 146
I've got a 19 850 174 that is going to be my backup sled next year since I've got a freeride on the way. I want to go down to 146 to have something better for family rides that are more trail oriented and also just to do 146 things since they look like a blast to ride.
Sleds miles out and beat so selling with the intention of just replacing with something shorter won't work since this one just isn't worth a whole lot. So should I look for a 155/163 tunnel to then cut down to fit a 146 or just cut mine down and build some suspension bracket braces to match where they would be on a shorter tunnel?
TRS
Life Member
4,118
6,275
Cody, WY
I have 155 rails that will fit your 174 mounting locations or drop brackets that will move your rear 174 mount forward to accommodate standard rails.
V
volcano buster
1,614
Stayton Oregon
How would you compare the handling characteristics of the sled with the different rear suspension mounting locations?
Reason I ask, the old Edge platform had 2 rear mount locations on the rails and brackets. The rear holes used for the 156/159 made a significantly more planted feel than the forward holes for the 136/144.
TRS
Life Member
4,118
6,275
Cody, WY
Here is a video of Toby running his 9 mod with the 155/174 long arm and a 220# RTS spring.
He runs the 155/174 in all his mod sleds as well as a few other RMSHA racers. This is a 155 setup. You can make it as wild or tame as you like.
I run a 175# RTS spring in my 165/174 backcountry setup. It still does hop overs.
