K
I have a 2009 summit X 800r. Out riding this weekend I landed on my side pretty hard on a whip. when I started my sled back up I got a engine knock code and engine light. the code has not gone away sense then and is there threw all rpm ranges and idle. motor runs great and can not hear any noise coming from it. after it happened at idle the sled would switch from forwards to reverse and back without touching the rer button. it but is not doing that any more though. I have taken apart all electrical connections and blown them out and all look good. I tried disconnecting the knock sensor at the connection and unbolting it leaving it connected. have had no luck. gas was fine as the other sleds in my group fuel up at the same pump before me. I had about 75 miles on it sense I put a new top end in it when it started. sled has not had ecm updated. thank you in advanced.
