I'm looking to see if someone can tell me the size of these bolts off a 2019 850 fly wheel and clutch cover? I want to go with titanium bolt through a local bolt supplier.
Both the 800 axis and the 850 would benefit from heavier bolts not liter bolts.
The rotating weight of both motors is already to lite in relation to long life.
Clutch life is already very poor on both motors..... we have Ben Adding weight for the last 3 years and it’s all plus’s across board.
Dan
I will now be re installing the ring gear that I took off. Dan is the man. I don't care what Kelsey says about him.Both the 800 axis and the 850 would benefit from heavier bolts not liter bolts.
Dan
You have to admit that there is nothing more fun than Dan and Kelsey going at it.
M6x1.0x10I'm looking to see if someone can tell me the size of these bolts off a 2019 850 fly wheel and clutch cover? I want to go with titanium bolt through a local bolt supplier.
Sounds like extra heavy tracks would be the better helper in that interpretation.Remember once wound-up, the kinetic energy helps take over when the loads are high on the track. So keep the weight up to help keep the RPM more in balance with the clutching. Less variance in holding upper RPM, more like a flywheel effect! Don't worry about the gyroscopic effect on handling, Too light as is! Mike
Very much agree on the harmonics, especially with a turbo.Both the 800 axis and the 850 would benefit from heavier bolts not liter bolts.
Dan
Dan make a clutch cover with your face laser etched on it. It would be like we are riding and clutching together.
