Clutch rubbing on side panel
XFIRE800
2,480
862
Aberdeen, SD
My proclimb without sucked in panels rubbed... I just made a brace with a chunk of aluminum and it was fine after that. Whats the brace like on the 2018?
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Wow, needs more strength or support in that area.
Or just put a big rivet like the 13-17's that rivet keeps the plastic safe lol.
Go Hawks!
Teth-Air
4,562
2,791
Calgary AB/Nelson BC
www.specified.ca
On my 2008 Ski-doo, I had to stick a piece of stainless steel thin plate on the inside of the panel with 2 sided tape. It got chewed a bit bit saved the side panel. A bit of preventative medicine is required here.
SnoPro1000
283
115
So far this is the only problem I have heard off, It'll be a pain in the rear, but a lot better then blowing motors and cracking bulkheads
H
Jan 30, 2017
Primary clutch rubbing hole in side panel.
Yeah I'm not real happy that my new sled has a hole in the side panel. From primary clutch think it's something that Arctic Cat should fix and warranty! Really like everything else no complaints other then that 350 miles later.
