I have an 09 M8 LE with the same hard steering. It is fine on the trail when I'm on it which is not very often. The problem lies is when you are winding through the trees at a slow pace. The sled will not turn. I have called a ton of dealers and every one has a different answer. The common on being, live with it. I have run my limiter strap out, gave it more preload, ran my front shocks low, checked ski alinement (sp). The last two dealers I talked to gave me the advice that was backwards of everything I have learned over the years. Try running your front floats with at least 75 lbs. Suck up your limiter strap one hole from full out. Run your ski alignment (right sp) with a 1/8 to 1/4 inch toe in. Start your front skid shock preload with about three threads on the bottom and work up from there. This is as far as I have got without more testing. I can't test for a few more days so let me know how it works. One more thing that I will do before I go out is spray all steering ends with Pam cooking spray.
