That's kind of a pricey experiment tho isn't it? Polaris has rebuilt the sled 3 times and each Mag piston has had the same scoring on the Exhaust side when he squeaked it, looks like a lean burn down. Polaris has reflashed the ECU twice, wouldn't if the ECU was partially burnt it not take the reflash? All factory OEM Polaris parts were used in the rebuild, pistons and cylinders mic'd good before install, injectors flow tested good, fuel pressure good, reeds are stock (good), TB boots were brand new. Its weird and he doesn't want to rebuild it just to have it blow up again so he wants to replace, first seeing if there's a used engine for sale before ordering a new crate engine. The only mods to the original is an SLP pipe/can, he runs Polaris Gold oil and non ethanol fuel.
Any thoughts???
