I completely forgot about this. But since I made this thread and its convenient I'll put the link and some torques in here for everyone. It's possible I made typo's so if something doesn't seem right, double check.
support.countrycat.com
Ski Bolt: 35 ft-lbs
Upper A Arm Ball Joint: 20 ft-lbs
Lock Nut: 45 ft-lbs
Lower shock bolt: 24 ft-lbs
Lower A Arm to Spindle: 45 ft-lbs
Tie Rod to Spindle: 32 ft-lbs
Tie rod to bracket: 20 ft-lbs
Upper A-Arm to chassis: 9 ft-lbs
Lower A-arm Front Bolt: 65 ft-lbs
Lower A-Arm Rear Bolt: 45 ft-lbs
Rear Idle Axle: 24 ft-lbs
Rail End Cap: 80 In-Lbs
Idler Wheels: 13 ft-lbs
Front Arm to Rail: 52 ft-lbs
Rear Shock Lower and Upper: 24 ft-lbs
Rear Idler Arm Upper and Lower: 24 ft-lbs
Front and Rear Mounting Bolts for the Skid: 40 ft-lbs
Exhaust Manifold Nuts: 12 ft-lbs
Cylinder Head: 13 ft-lbs and then 28 ft-lbs
Primary Clutch Bolt: 51 ft-lbs
Primary Cover Bolts: 120 in-lbs
Spider Nut: 450 ft-lbs
Weights: 50 in-lbs
Helix Screws: 120 in-lbs
Secondary Clutch Bolt: 60 ft-lbs
