I do a LOT of my playing in the trees, or getting thru the trees to go play.
With the new 07/08 700 RMK's it seems they have a lot of transfer.
I put the strap out all the way as I did in my old Gen II sled and found that was a BAD idea.
So I put it back in the middle and that helped a lot, however I am still getting way to much transfer. When you try to crawl thru the trees it wants to lift the skis and send you into the tree instead of around it.
I did notice that with me, my gear, spare fuel etc, the back of the sled drops about 6.5". My understanding is it is supposed to be a max of 5". The spring tensioner is set to max.
Here is what I am planning on doing.
Changing the top gear out to a 19. Give a gentler engagment.
Thinking of a heavier torsion spring, but not sure how big to go. Currently running stock.
How low of an engagment can you go before belt burn becomes a problem?
currently run the polaris stock recommended setup for 8kft.
