06 rmk 900 bogs and backfires, idles at 3000 rpm someimtes a little more once warm. sled will die or sputter and barely run when shifted into reverse, if you let it idles and slowly accelerate you usually get a 2-4 second burst of power up to about 8000 rpm then its just like someone hit the kill switch. if u put the sled from idle to WOT it will die almost instantly, pulled the tps sensor wire and it checks good with an ohmeter, have throttle bodies with new tps on the way, sensor was set at polaris dealer and it made it worse, now it doesn't start unless i unpplug the sensor to start or pull it about 10 -15 times. anyone got any ideas that i should check while i wait for my new tps and throttle bodies to get here ?
mods i have are- CPI single pipe, CPI glass pack twin muffler.
any help would be awesome
