Power to Weight Ratio: Four Stoke vs. Two Stroke
27,411
Ahh yes, the ETERNAL never ending debate of Power to Weight ratios for 2 strokes vs. 4 strokes.
2015 Polaris Pro 162 800 RMK
Wet Weight 493lbs
Horsepower 150 (sea level)
Power to weight ratio = 3.28lbs per HP
(I list this just for base comparison, NO ONE is going to seriously ride a normally aspirated 4S Yamaha Viper in the mountains, while the overwhelming majority of 2S riders do ride without a turbo. I am trying to honestly compare apples to apples here..and I make NO argument that a boosted 2S will win every time until its engine fails from the added stress while the 4S runs for another 15-20K miles)
Yamaha Viper 162
Wet weight = 595lbs
Horsepower 125 (sea level)
Power to weight ratio = 4.76lbs per HP
Yamaha Viper 162 with OEM Turbo 6lbs Boost
Wet weight = 610lbs (15lbs added for turbo)
Horsepower 180
Power to weight ratio = 3.38lbs per HP
Now lets take these two sleds up into the mountains and ride them at
6,000ft
Wet Weight 493lbs
Horsepower 123
Power to weight ratio = 4.00lbs per HP
8,000ft
Wet Weight 493lbs
Horsepower 114
Power to weight ratio = 4.32lbs per HP
What happens is that just as soon as we get into some real world riding in the mountains the 4S is suddenly able to hold it's own. Of course, if the 2S rider boosts his engine, then he clearly wins the day. But I think the honest reality is that "the overwhelming majority" of 2S riders do not invest the money in a turbo or supercharger, whereas its just the opposite for 4S mountain riders.
Doesn't mean a 4S will EVER compete against a 2S on WEIGHT, but they can compete pretty well in a general sense on the Power to Weight Ratio.
And.
If we begin to raise the boost levels up a bit, as SO MANY of our 4S riders do, then the numbers really being to shine.
Yamaha Viper 162
Horsepower 200
Power to weight ratio = 3.05lbs per HP
Yamaha Viper 162
Horsepower 225
Power to weight ratio = 2.71lbs per HP
Yamaha Viper 162
Horsepower 250
Power to weight ratio = 2.44lbs per HP
Dartos
1,574
668
Craig, CO
So you are indicating the OEM turbo builds boost to an absolute pressure, not a prescribed boost above ambient pressure? If the boost is above ambient pressure, it too will loose horsepower with a gain in altitude, but you already knew that, just pointing it out for the rest of the class.
(Also all your examples at the bottom have 6 lbs of boost)
Nov 27, 2013
1,962
917
Mountain States
Wet Weight 493lbs
Yamaha Viper 162
Wet weight = 595lbs
Horsepower 180
6,000ft
Wet Weight 493lbs
Horsepower 123
8,000ft
Wet Weight 493lbs
Horsepower 114
And.
Yamaha Viper 162
Horsepower 200
Yamaha Viper 162
Horsepower 225
Yamaha Viper 162
Horsepower 250
That is certainly one way to look at it......For the type of riding I do "peak hp" enters into the equation only when I'm climbing something steep even than there's always more hp (turbos) than most will ever use......I'm more about the " torque curve " mid range especially for boondocking & tree riding in and out of the throttle BRAP BRAP BRAP .... From what I hear the Vipers "mid-range torque" is good and really responsive perhaps nots as snappy as a 2S but pretty darn good from what here.....Clutch Setup playing a hug factor.
Weight on the other hand always feels heavier at lower speeds vs higher speeds...To Yamaha credit they do a great job with getting the center of gravity spot on to make the weight almost disappear.
DPG
27,411
That's an interesting point on the torque curve.
Will need to do a little hunting to find some dyno tested in graphic form that can be posted for comparison
bholmlate
1,400
778
Reno, Nevada
Yes Christopher
I am not sure what the point of this thread is other then to get every 2s guy into the Yamaha forum to say how wrong you are and the viper will never be able to compete on a level playing field with the 2s Dont get me wrong i own a 4s and the viper looks like a great sled as well. All you are really doing here is showing how you can use statistics to prove anything you want as long as you ignore anything that goes against what you are trying to prove.
DPG brings up a good point with the torque curve because torque is the force that gets you moving. in tight tree or any area you start and stop a lot it would an advantage to have a torque monster which 4s often are
27,411
Yes Christopher
This thread evolved out of another thread where a member was claiming that 2S sleds ALWAYS win on the Power to Weight ratios, and its simply not true.
As for the Torque.
Right now I don't know the answer, but I will start hunting for some Dyno graphs so we can see...
Nov 27, 2013
1,962
917
Mountain States
I'm confident the Vipers mid range torque will be very good especially if you keep the flipper engaged with the rpm so your alway in the sweet spot of the power band.....Best way to do this is watch the tach not the speedo.
DPG
Oct 14, 2014
40
29
So explain to me why you allow for a turbo to be added to one sled and not the other? You can turbo up a Pro just as easily as you can turbo up a Viper. Comparing a turbo sled to a non turbo sled and claiming apples to apples is disengenuous at best...
I think what needs to be done, if this comparison is to be at all valid, is to use a turbo 2s when comparing to a turbo 4s. Of course that would ruin your power to wieght argument wouldn't it?
27,411
Go back and read what I said.
A boosted 2S wins hands down!
I thought I was VERY CLEAR on that.
My point was that the overwhelming majority if 2S mountain riders do NOT use a turbo, while it is just the opposite for 4S mountain riders. The majority of them DO use a boosted sled.
Out if 1,000 Pro RMKs on the mountain, would even 10% of them be Turboed?
Out if 1,000 Vipers on the mountain, would even 25% of them be non-Turboed??
turbo800
848
214
Northern,UT
Not sure if it matters or not, but CAT's claiming 135HP out of the 7000 vs the Viper @ 125HP listed above.
I've heard the Viper regularly dynos at 130-132HP...
TRUEBLUEMAX
751
280
Hooper, Utah
Show me a $2000 turbo upgrade for a two stroke that doesn't void the warranty. No such thing. That's why there will be a lot of turbo Vipers and not many turbo smokers
27,411
I have asked MPI for some of their Dyno results from all the testing they did this year. Hopefully they can share some of their testing results for Aspirated and Boosted sleds.
27,411
Speaking with NO real firsthand knowlege here.
Are there any legitimate mass produced 2S Turbo kits for $2,500 on the market??
The MPI Turbo option on Snowchecked Vipers is an absolute STEAL in the industry.
