That is the wrong approach and will increase TSS movement. You just made the rear push harder, sooner on the TSS. 8.5 inches of spring on the rear. 8.25 on the front... crank the TSS upto 400psi and you need an x-tune to truly make it work properly.
I tried cranking both the front and rear (separately, and both together) and cranking the rear is what made it trench less. I preferred the way the bike rode with less preload on the rear but the bike needs to not be stuck to ride so more preload it is.
Jumping on the pegs the TSS is compressing before the skid shocks.
Does anybody the Xtune specs, or even what shim stacks are stock in the TSS shock? I'm not going to send it out and I'd like to avoid disassembling the shock to see what stack is in it, order shims, reassemble so I can ride then disassemble to revalve again once shims arrive.
