I
I am looking at trying to get a little bit more weight transfer on my king cat. I have heard to tighten up the front limiter strap 1 hole. Any help would be great. thanks
If you want more weight transfer - loosen the limiter strap and increase center shock preload. Moving the top of the rear arm forward and up will increase weight transfer. Dropping the front arm down in the tunnel will also increase weight transfer - I would start with the limiter strap and preload adjustments before drilling holes.
Generally, drop brackets will help on a sled that transfers too much (98 Summit X670, for example). .
I could be wrong but every sled I have ridden with drop brackets has LESS weight transfer. Thats why I dont run them. I had a set on one of my selds, rode 3 times before selling them. ride with a guy that hs them, i I dont like the way his sled handles at all. Just my .02 but I dont like drop brackets if you are looking for weight transfer.
