Fuel problems with '94 Summit 583
Dec 30, 2017
I have a '94 Summit 583 with a fuel delivery problem. My first question is, does this sled have a fuel filter? The reason i ask is because this sled idles fine, but when i take off on it the sled stalls out within 75ft. I replaced the carbs, airbox, throttle linkage and CDI. No difference! So, I need help!!
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
There should be a brass filter on the end of the pickup line inside the tank.
Mountain Cat
Sep 24, 2009
605
136
Yakima Wa
A lot of those carbs had a screen above the needle & seat. Check your fuel pump, impulse hose & tank vent in addition to the in-tank fuel line & filter.
N
nuttyn01
811
220
Sioux Falls, SD
Do everything stated above and I would strongly suggest getting rid of the HAC system and jetting accordingly. With the age on the machine the rubber diaphram is probably dried out and cracked. They worked great until they didnt. I used to have to rezero mine until I eliminated it completley.
Ox
Snowest's Axe Murderer
1,525
605
NW Ohio
www.midwestproductionmachining.com
But you didn't change the fuel pump or the pulse hose to it from the motor?
