WRONG WRONG AND SORT OF? I can't say for absolute certian on 1000's but m5/m6/m7'm8 proper air intake and you can run the exhaust under water or packed deep powder without bogging. The two issue are interrelated becasue once you cut air intake and have the sled running real......read real rich, then lots of resistance at the tail pipe creates a problem, forcing exhaust up into engine compartment where your engine SUCKS HOT AIR,EXHAUST AND STEAM off the motor if you haven't fixed that.
Go back and search the early season threads on making your headlight area into an aditional air box and adding air suppy to it behind the windshield. Does cost about $8 plus 2 hr shop time.
take your plenum off the sled and stare at where the air comes into it!!
1. seal the plenum from sucking hot air off the pipe and 10 times worse...... hot steam / plus exhaust from under the hood........and they all do stock suck underhood NO GOOD.
Use lots of aluminum foil tape, works as good as other way fancier setups I built and tried.
Don't cover the plenum hole...............seal the entire headlight/speedo pod area off from engine compartment.
Now add as many extra behind the windshield holes screened to double or triple the side intakekes, and while your at it, make some more bigger holes in top of plenum, dig in your wallet and buy some of the water proof side screen material from SLP and glue over the holes with 3m emblem adhesive( does turn this into the unltimate $21 fix now ).
Now borrow a scuba outfit, wait for the right day, 4' plus of light powder is ideal, ride till you hit something solid, then backup and head for the truck.
