Already have BDX Intake With SLP Pipe. What other mod to compliment this package-a head, bore kit, or just nitrous would give more bang for torque?
Hi, are you getting away using a BDX box with the SLP pipe with no fuel controller?
I was wondering if that was ok?
I'm looking at RX TeK porting.
No controller for me 09 m8, BDX box, SLP pipe. Checked wash , looks good. Air temp. about 20 deg. above. We ride starting at 10,000, mostly arround 12,000'. My only concern is when the temp. drops down around 0. According to my wash I have a little to spare. Allso considering head, maybe cyl port, and then would have to do fuel controller?
best mod for the $$, RKT head. Hands down.
I seen the RKT Head advertised as a 15HP gain with stock exhaust. That is about the gain I feel I got with the pipe and intake mod yet lost weight and heat as well. The 40/36 Helix helps and shift assist. But I Still miss the torque I found in my old KIngcat. I thought maybe a head but I still want to run pump gas.
if you have an SLP single pipe and can set up and you want to run the RK tech head do you have to run race fuel or does premium do the job .. also do you need a fuel controler?
Hey, not to change the subject but Muzbomb how do you like your Bid Dog barker can? Its one of the only can's that doesn't loose HP, but is it annoyingly loud??
