The wrap doesn't cover everything though, you can see bright colors through the gaps in the wrap pieces, especially if it doesn't match the wrap colors. Black is best if you're gonna wrap it.Ok so don't throw stones at me getting to old to dodge em' .. LOL .....
BUT ..............................I see all the concerns on colors when probably 1/2 OR MORE will wrap their sled anyway... To me get the options a guy wants. Wrapping a sled seem to be popular these day's
No one knows for sure yet but the spec. sheet list the IFP or the AC5S shocks as options on the base model.the base model will be black with ifp shocks only
the sno pro will be green with ac5s shocks only
Do you have pics of “a bunch being broke“ or is this another turboless terry baseless, unproven, my sisters cousin in laws father in law broke one? HahahahahaHopefully they fix their running boards for 25. Cracks me up that they say they've never broken a set but if someone does, they're easy to change. A bunch being broke but we've never seen that before.
"We've never seen that before" is the default reply of any service rep.Hopefully they fix their running boards for 25. Cracks me up that they say they've never broken a set but if someone does, they're easy to change. A bunch being broke but we've never seen that before.
The way I read it is that the base model has the IFP and the Sno Pro has the AC5S shocks.No one knows for sure yet but the spec. sheet list the IFP or the AC5S shocks as options on the base model.
As stated earlier. The spec. sheet doesn't even mention the Sno Pro. So take it for what its worth. (tomato, tomoto)The way I read it is that the base model has the IFP and the Sno Pro has the AC5S shocks.
Look at post #3As stated earlier. The spec. sheet doesn't even mention the Sno Pro. So take it for what its worth. (tomato, tomoto)
no it doesn't, you are reading the spec sheet wrong. For example, the column with the header M 600 includes the the specs for BOTH the base model and the sno pro. They are grouping those two together to save space on the sheet and differentiating only the Mountain Cat. As shown in the table at the bottom of post #3, the base model comes with IFP shocks and the sno pro comes with AC5S.No one knows for sure yet but the spec. sheet list the IFP or the AC5S shocks as options on the base model.
That's because the only thing differentiated it from the base model is the colors and shocks. Therefore, they combined them in the same column for the spec sheet in order to save space.As stated earlier. The spec. sheet doesn't even mention the Sno Pro. So take it for what its worth. (tomato, tomoto)
black will be available in 146, 154, and 165Arctic insider's post only showed the black in a 154 but if it comes in a 165 all is good I will just upgrade shocks.
It seems you are in the know on these sleds which is great thanks for the info. I do have one question can you confirm fuel tank capacity? Arctic Cat marketing has 10.4 gallon but a earlier post from the owners manual has 9.4 gallon? Another question do you know the belt drive ratio for the 858? ThanksThat's because the only thing differentiated it from the base model is the colors and shocks. Therefore, they combined them in the same column for the spec sheet in order to save space.
I'm guessing it's 9.4 as the spec sheet has a higher probability of being right. No one probably communicated the final official capacity to the marketing team and they are just copy/pasting last spring's information. As for the belt drive ratio, I have no idea. I'm guessing it would align with whatever they did on previous generation mountain sleds. If previously the 600/800 had the same gearing in similar models, then i would expect the 600/858 would do the same.It seems you are in the know on these sleds which is great thanks for the info. I do have one question can you confirm fuel tank capacity? Arctic Cat marketing has 10.4 gallon but a earlier post from the owners manual has 9.4 gallon? Another question do you know the belt drive ratio for the 858? Thanks
If the tank is 9.4 gallon you would think they would offer a fuel can for the attach system but currently they don't maybe it's still coming?I'm guessing it's 9.4 as the spec sheet has a higher probability of being right. No one probably communicated the final official capacity to the marketing team and they are just copy/pasting last spring's information. As for the belt drive ratio, I have no idea. I'm guessing it would align with whatever they did on previous generation mountain sleds. If previously the 600/800 had the same gearing in similar models, then i would expect the 600/858 would do the same.
