Anyone have pics of the arctic cat pro mtn boards? Also what are your thoughts about them?
Sent from my Pixel 3 using Tapatalk
Ya those are what im talking about, i was looking at the bdx ones but i wanted the charcoal color.If your talking about the tubular ones with the little plastic traction cleats, I had those on my '14 the last few years. I liked them. The only complaint I had was that wetter snow would occasionally stick to the plastic cleats on the cross bars and ice up. I pulled the plastic grips off and ran screws like some of the other boards for a while but got tired of constantly replacing screws and went back to the plastic grips. I'll probably go with bdx on my '20 because the grips are built into the tubes so no screws or cleats to add.
As far as fit, build quality, and overall function the cat boards were great. just that occasional issue of ice on the plastic, but that really wasn't to bad. I've also wondered how the billet boards cat sells work, but haven't really seen much talk about them.Ya those are what im talking about, i was looking at the bdx ones but i wanted the charcoal color.
Is it a flat plate against the tunnel? I had bmfabs on my axys, you would be supprised how much ice built up on the tube against the tunnelAs far as fit, build quality, and overall function the cat boards were great. just that occasional issue of ice on the plastic, but that really wasn't to bad. I've also wondered how the billet boards cat sells work, but haven't really seen much talk about them.
Yes, flat against tunnel as the pics above show.Is it a flat plate against the tunnel? I had bmfabs on my axys, you would be supprised how much ice built up on the tube against the tunnel
Flat but because you cannot cut the tunnel flat it results in a surface that holds snow similar to or worse than the BMFAB round tube inside.Yes, flat against tunnel as the pics above show.
