2020 SKI-DOO SUMMIT X WITH EXPERT PACKAGE
• Spring-order only • 850 E-Tec • Designed with input from backcountry riders Carl Kuster and Tony Jenkins • Features everything the Summit X has, with these upgrades: • Shortened tunnel. It’s essentially the tunnel from a 146-inch track Summit on the Expert 154, and the tunnel from a 154- inch track Summit on the Expert 165. • Minimalist lightweight snow flap. • Kashima-coated KYB HPG Plus front shocks • KYB HPG Plus center shock • KYB Pro 36 EA compression-adjustable rear shock • Lightweight coil shock springs have fewer coils • New expert-level stiffer shock valving • New lightweight spindle with updated bottom profile • New ski rubber, designed to keep the ski flatter on the snow surface in rough terrain for improved sidehill control • New FORTY7C lightweight mountain seat. Developed with Carl Kuster, the seat has a lower profile, shorter length and narrower shape • New handlebar with smaller-diameter grip. The handlebar ends have been machined down 2mm to accept a new grip for reduced arm pump and greater ergonomic comfort • New 4.7-inch bar riser block • New low handlebar strap with more flexible material • New flexible hand guards, protection for the brake reservoir • Factory external limiter strap adjuster with two settings for quick adjustments • Adjustable limiter strap • Updated profile running boards • Two unique color ways: Ultimate Black / Orange and Lava red / White • New drive belt with new PBO material and design • SHOT available • Sea-level calibration available • Two track options: • 154x3 • 165x3 2
hope this helps.. Google is your friend for finding stuff.
