They are shipping now. SLP includes a resistor for the exhaust sensor so that a reflash won't be required for higher elevations. 5'000' & above I believe?
The pipe fits much better than last years for the 700. Hood clearance is good, the pipe fits over the square cross brace so lower in the chasis. Fit is perfect on all components.
Kit includes the Y pipe, pipe & silencer all ceramic coated. The "Y" is a SOB to change. I had to cut a 6mm allan wrench to get on several bolts. My advice would be to leave the two easy bolts til last. I used an extension magnet to help with alignment of the wrench on 2 of the lower bolts. Will take an hour to make the change for most of us.
The only clutch change I made was from 62 to 64 gram weights. The sled ran great but I didn't have a comparison to measure performance yet. It takes more torque to pull heavier weights & I've heard about a 3 sled length improvement. SLP says 6.2 HP & -10lb's. Crisp & clean running with the pipe.
Probably room for improvement with the driven helix-needs a steeper initial angle. Drag raced a mix of 06 & 07 Doo's & Polaris 7's & 8's on a lake at 7500'. I got beat 2-3 lengths out of the hole. Not shifting quick enough so track slow to hook up in the powder. Didn't take long to pass all but a friend with the Carl's 840 BB-what a beast. One 07 Summit with a P85 primary ran good too. He pulled me 3-4 lengths to start & it took longer to catch & pass him-he was 50+ lbs lighter. I beat a stock 800 Dragon too but it was on it's first outing with a heavier rider. It will be interesting to see how the Dragon compares to the XP on the hills. I'm guessing that better clutching & track on the D will offset the lighter weight of the XP.
