3211216 belt
TRS
Life Member
4,119
6,277
Cody, WY
Has anyone else measured them lately?
I had a customer call that measured his belt because he was getting a wide belt to sheave measurement.
1.406”. Hmmmm.
I called a friend of mine and had him measure 3 belts.
1.405”/1.410”/1.409”
I stopped and picked up 3 belts today.
1.405”/1.413”/1.422”.
I haven’t seen them at 1.47” but measured them in the past at 1.437”.
Lobster Carl
134
160
That certainly would mess some stuff up if they are assembling primarys for 1.47.
My belt off my new sled that has been moved twice is 1.412. And other new one is 1.422
carbontj
222
421
indianapolis
I bet if you measure the OA circumference they will vary 1/8....not sure if they ever cut 2 belt the same...we set cleanse at .020 just inn case of a wider belt...
U
45
Without a concern for a wider belt what would you set it at? I shoot for .020”. Current sled ended up .025 to get sheeves to align per it’s original balance
I forget #’s and I’ll check later but there was a big difference between my new belt and the one that had 200 miles on it when I bought the sled. I just figured it was wear. Maybe not??
TRS
Life Member
4,119
6,277
Cody, WY
This confirms we need to check belt width and belt to sheave measurements for optimum performance.
Even with the OEM belt manufacture.
This may explain some of the creep we are hearing about. Along with belt to sheave measurements up to .120” from the factory.
Griff
162
Are other manufacturers' belts more consistent width and length than Polaris'?
zaasman
200
227
Yukon
1.406”. Hmmmm.
Are these projected width measurements, or straight width between flats of the top teeth?
New 3211216 I just measured (purchased last season) comes in at 1.460 projected (1.418 flat to flat).
