J
So if I choose to run the 5203, is it determined that a sealed bearing is still the way to go or should I opt for the open design assuming it's getting enough lubrication from the oil in the case?
If you do the 5203 without machining the shaft you may have clearance issues and the bearing will be destroyed in short order.
Spoke extensively with Jeff at BDX regarding the shaving of the drive shaft.
He has replaced 100 or so bearings without ever shaving the shaft, claims it is a non-issue.
The key to proper install is to pull the Diamond Drive off the machine, replace spacer and faulty bearing and re-seat cover and torque according to AC specs. Jeff says problems occur when you try to replace bearing and recover WITHOUT removing the DD drive. The cover will not seat properly and cause faulty drive shaft and bearing function.
The reason I am posting is there are 5 plus DD bearing posts and there seems to be no definitive answers. Isn't BDX the original designer of the DD? Don't they work on them extensively? Wouldn't they be the best resource for this? That said I am still nervous about mucking with my brand new 2011 M8 while under warranty.
I hear ya and BDX would be far more knowlegeable than I. I would say they were the original designers but are not in charge of current manufacturing quality control. I took measurements with a digital caliper and straight edge and can guarantee you that without knocking a few thousands off the shoulder of the shaft that the wider bearing would be in contact with the case with the cover tightened down regardless of whether or not it was in the machine. I did take all my measurements with the DD on the bench so the mounting bolts were not twisting or putting any other pressure on the case.
Each to their own though. My sled is still under factory warranty but that wouldn't have done anything for me back in the boonies and the bearing in mine was shot at 400 miles. When I say shot I don't mean getting rough I mean seals gone and balls getting crunched up in the gears. I had to take the entire drive apart to get all the shrapnel out.
So I have been reading as much as I can on the bearing failure on the Diamond Drives and how people are machining a bearing down to replace the old bearings on what looks to be 09-2010 models. I have seen a few questions asked about the 2011 models and if they are having the same issues, but haven't seen any clear answers.
Does anyone know if the 2011 M series sleds are having these same issues with the Diamond Drive bearings, or did A/C correct the problem? I haven't had any issues with mine, but want to know if I should tear it apart or not?
Sorry if this has been addressed, but I haven't been able find this answer.
Thanks -
Well here is my answer. 2011 M8 with 345 miles and this was all that was left. I did check and measure everything out and I had to cut .057 off the shoulder of the shaft to bring everything back to OEM specs. Nice.....
Thanks for the advice. I will be measuring when I do my bearing exchange shortly because of posts like yours.
Makes you think about the crappy quality control AC must have if they can get such a variety of variances on one issue. You'd think it would be one problem consistently one way or another.
