Well, I wouldn't say all the DPM manifolds were junk, but between the 02 HOODED NEEDLE JETS, flaking ring issues, and dpm's being calibrated rich, that year wasn't the best. I rode mine stock for a couple years, then it just started to run crappy rich, got rid of the 520N jets for some 510 or 500's, one or the other. Xtreme Performance down in Colorado was doing a carb rebuild on the 02 carbs at the time, setting them up with hooded neddle jets, adj. needles, pilots, mains, dpm unhooked, lines plugged and vented to the airbox. I choose to install Jack Harris Power Jets to the carbs so I could give them more gas when jumping between elevations, gotta run egt gauges with this setup, or read plugs and know your setup.
I eventually put an RKT head on and the sled wouldn't run right, just boggy. Realized it was rich with 480 mains, ended up down around 410 mains with the RK Tech head,14.5:1 domes running 50/50 race gas and premiun at low alt., premium at altitude.
For you I would advise checking your compression, if it's low or uneven, get a set of SPI double ring pistons, and caged needle bearings, find a set of carbs off an 03-05 800, maybe a DPM manifold off of an 03, set of reed spacers, and if you can find some V-Force reeds of Boysen Rage Cages do yourself a favor and get rid of the stock reeds that are going to delaminate, leak air and burn a cylinder down. I fought burn downs on my 02 for 2-3- seasons, carb boots didn't look bad until my boy completely pulled one apart taking the airbox off last month. From the looks of the corroded aluminum under the rubber laminate they had been leaking for a long time. I found some other Doo boots on ebay, they didn't even last for a couple tuning runs and they literally fell apart, I siliconed them up good and let them dry for a day and a half, rented a Poo Pro for a day so my son could ride, and put the siliconed boots on the next day, a couple zip ties around the thermostat housing to the carbs for suppot and that sled ran the best it has for a few years, when I got home from that weekend I found a set of V-Force3 reeds on swap meet, bought 'em, put 'em on.
If you need rings,bearings,etc. go to MCB Perf., he can set you up with the whole kit to rebuild the top end, for a good price.
