Rode all Sunday with front skid shock removed due to broken shock mount. This is a 154 with Simmons ski's. The point I am making here is that the front shock in the rear suspension is too short to provide enough lift to make the sled steering feel light. This is why on the 2010 models, this shock will be longer, to give the required lift. If you want to reduce ski pressure, you must lower the front swing arm mount be 7/8" in the tunnel. The short shock is the main reason so many are complaining about rear sag. The front shock is supposed to share the load with the back and being so short, it is not which ovrloads the rear. If there was adequate pressure from the front shock, I would have really noticed lots of difference from stock when I removed the shock all together. Well it was harder to steer but not much. For thoses guys who simply let the limiter out, your not getting much lift as the shock will be fully extended way before the strap tightens.
Why is my shock mount broken? Because before lowering the swing arm, I tried moving the shock in the rail to get more lift. I over-did it and the shock was bottomming which damaged the mount.
