09 M8 steering post removal ?
IDspud
3,998
Oakley, ID
Tip it on its side, between the track and the front of the tunnel you will see a bolt. Much easier than it sounds.
KSH
Steering Wheel Holder
3,774
1,857
Larkspur, CO
How do you release the post from the swivel point at the bulkhead? Is there a pin to remove or special tool required.
If you look up under the tunnel in front of the drivers you will see a nut, that's the bottom of the steering post.
SLEDIOT
2,188
285
48
Dawson Creek BC
Worse part is U have to remove yer gas tank and pull it back a few inches to get the bellhousing thru the 2 teflon brackets to remove it.
Nov 3, 2009
166
9
or move the A frame fwd slightly, 4 screws, 2 nuts
Changed way too many posts...
+1. You need to take one bolt out (top) on each side in the lower part of the A Frame to get it to rock forward. Located near the secondary and near the brake rotor on the other side. Just loosen the other 2 and it will easily pull forward.
Thats the way to do it. Make sure you have a long extension (10") and a swivel adapter to get to that nut under the track. Makes life a lot easier.
skimike
191
14
bakersfield
you will need to hold the swivel bolt from the top with a 1/2 inch wrench otherwise it will spin. its very easy to change , it about a 30 min job
SLEDIOT
2,188
285
48
Dawson Creek BC
Or just take the 2 lil easily assesible nutz off he rear of gas tank and slide it back a few inches. Actually the easiest.
