Upgrade to Premium
Yamaha: 2-stroke Includes all Yamaha 2-strokes, Viper, Mountain Max, etc
Reply
  #1
Old 02-06-2017, 12:35 PM
bigcrash24 bigcrash24 is online now
Currently: Training 9yr old to ride!
Basic Member
bigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond reputebigcrash24 has a reputation beyond repute
Default Removing front shocks and clutches from '98 mountain max
Hi,
I will be removing the front shocks and both clutches from a 98 MM.
Anyone have tricks/tips/hints for doing so?
Thanks,
BC24
Rate this post: Yes | No
  #2
Old 02-06-2017, 09:58 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
The shocks and secondary clutch are easy. Just take out the bolts. The primary clutch will need a good quality clutch puller.
Ken.......
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
The Following User Says Thank You to Givemeaboost For This Useful Post:
bigcrash24 (02-06-2017)
  #3
Old 02-10-2017, 10:48 AM
Basic Member
Default bent the puller
so...I bent the end of the puller.
I cut the bent end of the puller off and then used it with the 'fill the hole with water trick'. that worked, along with gently heating with a torch too.
Click image for larger version
Name:	bent puller.JPG
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — works performance shocks mountain max Thread Starter — stock suks Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 03-12-2013 08:34 AM
Thread — Need Mtn Max front shocks! Thread Starter — martin1200 Forum — Suspension/Shocks (Swapmeet) Replies — 1 Last Post — 12-15-2011 09:38 PM
Thread — I need Mountain Max Front Shocks! Thread Starter — PowderMT Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 07-20-2009 09:06 PM
Thread — Full set Mountain Max Shocks Thread Starter — bigsno Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 01-03-2009 06:12 PM
Thread — Viper shocks on a Mountain Max????? Thread Starter — M.M. 700 Forum — Yamaha Replies — 2 Last Post — 12-13-2008 08:23 PM
no new posts
