Y
Do they fit, or do I have to go with the Cat boards? Search returned nothing..
You're all right, the ones they have I can get (Parts Unlimited gift card) are wider than stock. Will probably end up going a different way.
They do have a set that is for the new chassis, and are listed as narrower, but PU doesn't stock those.
If you end up with the new cat pro mountain boards with the plastic traction pieces do yourself a favor and install some traction screws instead. The plastic ones worked good for 1/2 a season now ice builds on them instantly, I had the same issue with the plastic grips on my old skinz boards
Well I made that mistake then.... I guess I'll just have to see. I figured snow wouldn't stick to plastic? Plus plastic would be way easier on your boots and shins.
You don't slip with the traction screws.
They do tear up your boots but they're awesome. Once the plastic ones get scratched up a bit, you they're almost as bad as stock boards.......kinda worse.
You can always do the screws later.
Once the plastic ones get scratched up a bit, they're almost as bad as stock boards.......kinda worse.
Day 1 yesterday, and the boards were a slip and slide. Well, not as bad as my stock Pro RMK boards, but very disappointing for $400 and 6 hours of time...
Let me tell you how badly I DON'T want to drill out all of the 60 some odd rivets I sunk into those tubes...
