Rod,
If you have not had the shocks serviced recently... the front track shock is problably low on pressure... take it to a dealer that has the equipment to nitrogen charge the shocks... take them all up to 225 lbs and you will be much happier.
If you have over 1000 miles on them... have them all fully serviced (oil etc)...
These shocks seem to do best with a "top up" of nitrogen at the beginning of Every season.
Nose heavy = Low front track shock pressure. (If the "nose heavy" feeling has increased with time).
Walker Evans (directly) can service them, update them with the latest valving/pressures and give you a very quick turnaround time if you talk to John in service and ask nicely. By sending them into Walker, you will not have to wait for parts should you need any.
www.walkerevansracing.com
Give em a call If you 2 day'd them on monday, you would have them back on friday with 2 day return if you make prior arrangements.
The 2009 shock valving on these units makes a big difference.. many on this forum will tell you to get other shocks... but for most of the mountain riders, these shocks will work fine. Walker can handle this too.
This is a good read
http://www.snowest.com/forum/showthread.php?t=82007
I have also changed my thoughts on the sway bar on the 2009 to agree with Ron in this post. The 2005-2008 sway bar setup has a lot of "stiction" in it and is not smooth moving thru the A-arm/swaybar bushings which wear and make it "klunky" in operation. It takes a bit for the sway bar to move past the "klunk" in the bushings and this causes the sled to lurch and dive a bit. When the bushings are in good shape it works well. You can make the 2007 sway bar setup slide easier in the a-arm plastic bushings by rounding the ends of the swaybar and putting some decent trailer bearing grease in the cup every 3-4 rides.
For as cheap as they are... replace the sway bar bushings in the A-arms and at the bulkhead if they are worn or have high mileage.
I'd also protect your investment with the perforated neoprene shock covers from
www.skinzprotectivegear.com on the ski shocks. Any minor nicks in the shaft will cause you to loose pressure in short order.
http://www.snowest.com/forum/showthread.php?t=98157
