R
Ive had two fail.
Glad to see that it all worked out.
This is a common problem and as I've mentioned earlier the problem is a domino effect problem, cause the culprit in most cases is the resistor who caves in and lets the hig peaks of current from the stator directly in to the V.R., this will cause the transistor in the V.R. to collapse and send the unprocessed current directly out to the machine and the ECU causing it to fry...
so is the voltage regulator what is causing my brothers 08 D8 to barely idle? the sled still runs, but you have to always be on the throttle just a bit to make it idle, maybe his v.r. is going bad slowly? any suggestions?
also i just got a 2010 D8, any suggestions on avoiding problems like this?
SS:beer;
That's what mine was doing and it was the v.r. causing the erratic idle.
when you say reisistor are you meaning the capacitor? where is the reisistor you speak of?
thanks
Got a call from my dealer today, Polaris says they will pay for the regulator and the ECU and I need to pay a $50 deductible and for labor. WTF is with the deductible?
